Project log - CNC upgrade
Re: Project log - CNC upgrade
Hey look, it's a pile of parts:
It looks like the design work is approaching doneness, finally. Thoughts?
GermTheGeek
The only word that comes to mind is "Sexy". Looks good.rsilk wrote:It looks like the design work is approaching doneness, finally. Thoughts?
Update tiem!
Got the X-axis rails fabricated and mounted, and a stand built for the torsion box.
The lead screws and nuts have arrived, but we're still waiting on all the bearings and such before those can be mounted. In the meantime, I'm trying to figure out a way to tension the lead screws so they don't whip around during fast moves (and to keep backlash down). Here's one option:
Hang on, that tensioner is stupid. This one's better.
I don't know if it would simplify your design.. but you can cheat and use ball bearings (like skate bearings) as thrust bearings. I am currently doing this on my mill. (If you think about it, they also server that purpose in roller blades and skate baords). You could put your ball bearings on the outside of your bearing blocks, and back them with your collars (and maybe nuts to allow you to pre-tension before tightening the collars). Looking good though.
-Matt
-Matt
It's a bit complicated this time around because I don't have nuts that mate with these leadscrews. Last time I used bog-standard 1/2-10 acme screw so nuts were cheap and easy to get. I'm using a 1/2-8 4-start screw this time around, so the nuts are hideously expensive. The thrust bearings aren't a big deal, and are only a couple of dollars each (and I'm poaching them from the old machine).
That sounds reasonable, carry on
-Matt
-Matt
Conrad_Turbo
If you have any worries about flexing you can always laminate the MDF with a sheet of aluminum or steel depending on the configuration and which direction you see the flexing in. Looks pretty cool!
I suppose I haven't posted an update in a while. Lots has happened!
