Boxform
Things made on the CNC
Hephaestus
Boxform
Post by Hephaestus »
like this, still building the tops
Hephaestus
Re: Boxform
these are the parts i need to cut, modeled in Sketchup. they fit within a 20"x40" envelope with about an inch margin.
thoughts?
rsilk
Re: Boxform
Post by rsilk »
Looks like it should work fine. You'll probably want to insert tabs between your pieces when you run it through CAM so they don't start flapping about, but that's easy enough.
