very cool!
Are you using emc2 or Mach3?
What tool did you use for isolation routing? Where did you buy it? Did it require much cleaning up a after?
Here is the only PCB I have milled (it required a fair bit of cleaning up the ragged edges of the traces):
It's a breakout shield for an arduino to connect servos, serial, bluetooth and LCD:
I did it on my converted harbour freight special:
-Matt
