So I'm placing an order and this is the list i have from you guys so far:
Props:
Jeremy Rans: 2x 7x3.5 prop sets
Jeremy Rose: ""
Jordan:""
Bergo & me: 10x 8x5 prop sets
James: 2x 6x5 Prop Sets
Other:
Bergo: turnigy talon2 frame, 5 cf2822 motors
Paul: ""
Jordan: one of the 400mm frame kit motors
10 low voltage buzzers
Rans & Rose: HKC6 charger
What else?
Hobbyking order
Re: Hobbyking order
Put me down for the following:
2x low voltage alarms (if not included already)
6x fc 28-12 motors
1x Prop Saver w/ Band 3mm (10pcs)
2x 7060SF combo (both standard and counter)
2x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) ( I think this is what we got last time)
I think that's it.... for now.
6x fc 28-12 motors
Re: Hobbyking order
Put me down just for this stuff instead of what you currently have me down for.
1 x Talon v2.0
5 x Turnigy fc2822
10 x 9x5 prop sets
2 x Bullet connectors
1 x Prop Savers
2 x Low voltage alarm
1 x HKC6 Charger
1 x Charging Lead set
1 x T-Connectors (battery connectors)
1 x Lipo Safe Sack
Which works out to 155.38 before whatever conversion/taxes there are.
1 x Talon v2.0
5 x Turnigy fc2822
10 x 9x5 prop sets
1 x Prop Savers
1 x HKC6 Charger
1 x Lipo Safe Sack
- Hephaestus
Re: Hobbyking order
i dont know if the 400mm frame motors are the same as the 550mm frame motors, but it's the 550mm frame i have and require a new motor for
- DigitalOSH
Re: Hobbyking order
That's a good idea.
Please add a lipo safe bag to my order also.
- Hephaestus
Re: Hobbyking order
here are the motors:
2200kV PM19M-2400:
2800kV PM19S-2800:
and the motor from my 550mm kit:
looks to me like i need a 2200kV PM19M-2400. and 3 prop packs
2200kV PM19M-2400:
2800kV PM19S-2800:
Re: Hobbyking order
was this all ordered yet? if not, I should get one of those lipo charging sacks as well. Also, I think we need prop saver adapters for our motors Paul.
- DigitalOSH
Re: Hobbyking order
Good catch. Order is going today, last call!
- DigitalOSH
Re: Hobbyking order
Order Placed, but some bad news. James and Jeremy Rose, your props weren't in stock so I didn't hold out for them
