Makerspace physical location
What area of Saskatoon would you prefer Tech works to be located in?
North Industrial
6
40%
Lawson
1
7%
University Heights
1
7%
Blairmore
0
No votes
Confederation
0
No votes
Core Neighborhood area (downtown/core)
4
27%
Nutana
3
20%
Lakewood
0
No votes
Total votes: 15
Post by Bergo »
Update:
created a new poll in the thread to get some opinions/feedback regarding where people would like to have the space. Feel free to leave comments. The idea for gathering this feedback comes from our last meeting where we discussed the possibility of having a space on the 200 block of 20th street west, some had security concerns.
Please pick your top 2, you are able to change your vote (if you happen to be persuaded in the discussion that hopefully follows)
More detailed breakdown of areas, feel free to suggest particular neighborhoods in your comments:
also, please refer to the following zoning map, depending on what activities we would like to do at the space, we likely will re required to occupy a space zoned at least light industrial (light grey on the map):
http://www.saskatoon.ca/DEPARTMENTS/Com ... ng_Map.pdf
Re: Makerspace physical location
Post by JamesCooper »
It may be a little out of the way for some people, but the size, facilities, and price all seem very reasonable. It is considerably cheaper than the commercial options and it even has bay doors. It looks perfect for our purposes.
We'd have to see the inside of the building but I think it may actually be a feasible option. It's north enough that we're not in a bad area of town and it should be easily accessible via circle drive. I emailed the owner to ask for pictures of the interior.
Good find!
Take a look at this one: http://www.loopnet.com/Attachments/3/6/ ... 619F39.pdf
2000 square feet, lease rate of $6.50/sqft/yr with occupancy costs of $4.45/sq/yr.
That basically means an operating budget of $1900/month INCLUDING utilities. Speaking of which, Power is 600 volt, 1200-amp, 3-phase.
This is a good one
Post by rsilk »
Not sure about this, but the 600v 3-phase power *might* be an issue. That's industrial power, meant to run very heavy equipment. Depending on what is available, we may have to install a transformer to bring that down to 120/240. I'm really not sure though.
Post by Bergo »
it just means 3-phase service, you still just use single phase 120v for normal wiring throughout the building. It just means that if we wanted to, we could get a huge ass CNC table, or a massive metalworking lathe :D
Also: that sapce on quebec is pretty sweet! does it have a service elevator? (2nd floor space, right?) what are the dimensions, looks long and narrow.
ADDandy
Post by ADDandy »
both those spaces look pretty awesome. the three phase power is pretty attractive
noblerider
Post by noblerider »
I have seen the inside of that blue and white building and it is very nice clean and spacious, personally I think it would be a very viable option.
Post by Kaldonis »
I would lean towards the first one over the second one simply because the first one is ground-level with an overhead door. I wouldn't mind being able to bring my car in to work on, plus it would make moving larger projects in and out a lot easier.
jmasterfunk
Post by jmasterfunk »
That first building looks really good. It's a big building and allows for that mechanical (or car electronics) side of things that some people may be interested in. I would just wonder if we have the membership base right now to support the cost of the building. Might also be worth looking into a bay in a strip mall, about 1000+ sqft. I'll keep my eyes open.
