Page 2 of 3
Re: Project log - CNC upgrade
Posted: Sun Oct 23, 2011 5:53 pm
by rsilk
Hey look, it's a pile of parts:
Posted: Mon Oct 24, 2011 11:07 pm
by rsilk
It looks like the design work is approaching doneness, finally. Thoughts?
Posted: Fri Oct 28, 2011 1:17 am
by GermTheGeek
rsilk wrote:It looks like the design work is approaching doneness, finally. Thoughts?
The only word that comes to mind is "Sexy". Looks good.
Posted: Sun Oct 30, 2011 9:30 pm
by rsilk
Update tiem!
Got the X-axis rails fabricated and mounted, and a stand built for the torsion box.
The lead screws and nuts have arrived, but we're still waiting on all the bearings and such before those can be mounted. In the meantime, I'm trying to figure out a way to tension the lead screws so they don't whip around during fast moves (and to keep backlash down). Here's one option:
Posted: Sun Oct 30, 2011 9:59 pm
by rsilk
Hang on, that tensioner is stupid. This one's better.
Posted: Mon Oct 31, 2011 1:56 pm
by mattf
I don't know if it would simplify your design.. but you can cheat and use ball bearings (like skate bearings) as thrust bearings. I am currently doing this on my mill. (If you think about it, they also server that purpose in roller blades and skate baords). You could put your ball bearings on the outside of your bearing blocks, and back them with your collars (and maybe nuts to allow you to pre-tension before tightening the collars). Looking good though.
-Matt
Posted: Mon Oct 31, 2011 2:03 pm
by rsilk
It's a bit complicated this time around because I don't have nuts that mate with these leadscrews. Last time I used bog-standard 1/2-10 acme screw so nuts were cheap and easy to get. I'm using a 1/2-8 4-start screw this time around, so the nuts are hideously expensive. The thrust bearings aren't a big deal, and are only a couple of dollars each (and I'm poaching them from the old machine).
Posted: Mon Oct 31, 2011 3:33 pm
by mattf
That sounds reasonable, carry on
-Matt
Posted: Tue Nov 01, 2011 10:24 am
by Conrad_Turbo
If you have any worries about flexing you can always laminate the MDF with a sheet of aluminum or steel depending on the configuration and which direction you see the flexing in. Looks pretty cool!
Posted: Sun Nov 13, 2011 2:44 pm
by rsilk
